9.2 on Intensity card only shows SD 720x480
Paul Bean
on Feb 2, 2012 at 6:44:56 am
I'm running Lion and just reloaded the BM 9.2 drivers, but I can only get SD output. I don't get any options under System Preferences to select a default output. And it seems nothing I do in FCPX will give me anything but SD. When I run FCP7, I still get all the BM HD options and all is still well there. Any ideas?
Paul Bean
Joshua Tree Productions
Las Vegas, Nevada
Kristian Lam
Re: 9.2 on Intensity card only shows SD 720x480
on Feb 3, 2012 at 3:18:05 am
Hi Paul,
We've had a few reports of this and are working on a fix for it. You can expect the fix to be released in a few days.
regards
Kristian Lam
Blackmagic Design
Philip Peinado
on Feb 5, 2012 at 6:37:46 am
I too am experiencing this, but I am using an UltraStudio 3D. I am also getting rather choppy video playback, with an error in final cut warning me of dropped frames due insufficient hard drive speed, however am using a Promise R4 thunderbolt raid which clocks in at 500MB/s.
Hoping its just the beta drivers.
Mark Dobson
on Feb 5, 2012 at 6:04:06 pm
Yes - this is a problem I've identified as well.
FCPX 10.0.3 / OSX 10.7.3 Intensity Pro only option is NTSC 720x480
I've reinstalled several times thinking I'd done something wrong so it's reassuring to find out that others are experiencing this issue and that a fix is being worked on.
But how exciting to have external monitoring again ( well almost )
Kristian Lam
on Feb 7, 2012 at 8:44:06 pm
Desktop Video 9.2 Beta 2 is now available. This addresses the issue you've seen with Intensity Pro.
regards
Kristian Lam
Blackmagic Design
Felix Rost
on May 4, 2012 at 4:40:26 pm
I think I have the same issue.
I searched BM archived drivers for this Desktop Video 9.2 Beta 2 (since reports on 9.5 are not very promising), but I can't find a driver with this name. Closest is Desktop Video 9.2.1 Is it this one?
