Jan 31-2012 FCP X update - broadcast monitoring via 3rd party cards/devices
Craig Meadows
on Jan 31, 2012 at 6:13:21 pm
http://www.macworld.com/article/165113/2012/01/final_cut_pro_x_gets_a_new_a...
Would love to know when we might get FCP X drivers for BMD products. Have two DeckLink HD FCP systems and willing to beta if necessary :).
Juan Morales
Re: Jan 31-2012 FCP X update - broadcast monitoring via 3rd party cards/devices
on Jan 31, 2012 at 6:26:54 pm
Saw that BMD just release version 9.1 of the Decklink and Intensity drivers. Will it improve Avid MC6 performance?
Ray Chung
on Jan 31, 2012 at 9:40:14 pm
That in particular would be very nice.
Reuben Evans
on Jan 31, 2012 at 6:29:58 pm
Post edited - I just realized this was the BMD forum.
Martin Smith
on Jan 31, 2012 at 6:41:41 pm
Does it work with Ultrastudio 3D?
Craig Meadows
on Jan 31, 2012 at 7:27:10 pm
I think the point of today's FCP X announcement is that drivers for 3rd party devices for broadcast monitoring like BMD products are hopefully imminent.
http://www.macworld.com/article/165108/2012/01/first_look_final_cut_pro_x_1...
Dan Swiney
on Jan 31, 2012 at 7:52:50 pm
My initial tests suggest the BM drivers don't work yet. Using 9.1 with an Intensity Pro and FCX it shows "no device found".
Tangier Clarke
on Feb 1, 2012 at 5:49:28 am
I thought it was something that would work after updating FCP X, but that's no the case. FCP X doesn't recognize my Multibridge Pro 2 with 9.1 update.
Tangier
Oliver Peters
on Feb 1, 2012 at 2:44:30 pm
You need Desktop Video 9.2 beta 1 for Mac OS X, which is being released today. Just found out.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Dave Bergan
on Feb 1, 2012 at 5:01:56 pm
It's out, but the only output option I get is 720x486 @29.97
Fabio Cormack
on Feb 1, 2012 at 5:03:10 pm
I downloaded the 9.2 beta driver - Blackmagic appears as an output device on the Final Cut X preferences but with only 1 option of output: a SD resolution of 740x 486 @ 29,97
But I have no signal output to my SDI monitor trough the Decklink HD 3D+
Anyone got video output yet?
Fabio Cormack
Davinci 8 - Tangent Wave - Decklink HD Extreme 3D+
Final Cut Suite
Adobe CS5.5 Suite
Rio de Janeiro - Brazil
Martin Smith
on Feb 1, 2012 at 5:19:31 pm
You have to set the video output resolution from the OS X system Preference Black Magic application.
If you monitor audio through BM device you have to set the ouput to blackmagic device in the sound preference of OS X as well.
Let me know how it goes for you, it's working "ok" here but of course this is beta so no complaining. The biggest issue for me is after playback from the timeline the screen is always black, it doesn't stop on the frame you stop or pause. You have to fiddle around with the scrubber or click on different clips to make the image come back.
Playback feels steady.
Dave Bergan
on Feb 1, 2012 at 5:31:32 pm
I checked System Prefs before posting, and it does say Desktop Video 9.2, but under the BM app in System Prefs, I don't have any resolution choices.
Martin Smith
on Feb 1, 2012 at 5:52:03 pm
If you have 9.2 beta installed your BM system preference app will show this from the settings tab. It should have a mention of FCP X under the "Set Default Video Standard as:" dropdown.
Just change the "Set Default Video Standard as:" to whatever you use for editing.
Dave Bergan
on Feb 1, 2012 at 5:57:26 pm
Surely it's that I have an Intensity Pro. I don't have all those options, including Set default video standard.
Tangier Clarke
on Feb 1, 2012 at 5:51:26 pm
Yep, that did the trick. A little cumbersome to have to switch it in system prefs, but it's a start.
Now if I could only figure out a way to get my edit out in a format my ProTools guy can use (a la OMF)...
I can dream can't I!
Tangier
Martin Smith
on Feb 1, 2012 at 5:59:24 pm
To export to Protools check this app. It's free.
http://www.automaticduck.com/products/pefcp/
Fabio Cormack
on Feb 1, 2012 at 7:42:25 pm
Still no image here. I can send the audio to the SDI monitor from FCPX, but no image.
I tried different resolutions from the BM preferences panel (set the video standard as) but no video out yet.
Any ideas please?
thank you
Fabio Cormack
Final Cut Suite
Adobe CS5.5 Suite
Robin Moran
on Feb 12, 2012 at 4:23:28 pm
how were you able to get the audio out?
Martin Smith
on Feb 13, 2012 at 6:00:29 pm
Yes,
You have to set the audio from the apple system preference / sound.
Set output device to "blackmagic design..."
thanks,
RJ
