Computer Design Question with Decklink Duo
Jarod Breshears
on Jan 18, 2012 at 7:03:34 pm
Hello everyone,
I want some advice on some system specs to build a machine that will utilize both sides of the Decklink Duo card simultaneously:
Side 1: Connect to either Sony Vegas or Adobe Premiere Pro 5.5 to do a direct to edit of my live program from the ATEM Television Studio.
Side 2: Connect to Adobe Flash Media Live Encoder 3.2 to stream a webcast.
Here is the only components I am concerned about in this setup:
What is the minimum processor requirement?
I am thinking of an Intel i7 3.4 GHz Quad-Core for this setup.
What is the minimum RAM requirement?
I was thinking 16 GB of RAM.
What is the minimum HDD requirement (This is more for speed)?
I was thinking a system drive of 500 GB SATA 3 and 1.0 TB project drive SATA 3.
Also, what should I use for a video card?
This system will be in a rackmount case as I will use it on site for all my various live events I produce.
Thanks for your input. It is very appreciated!
Jarod Breshears
Owner, Skeeterbuggins Productions
http://www.skeeterbuggins.com
