Decklink HD Extreme 3D audio input.
Peter McAuley
on Jan 13, 2012 at 12:49:23 am
Have not been able to get the analogue audio input signal. I have the input settings to SDI video & Analogue XLR audio. Mixer main output (xlr) patched to Decklink xlr audio input. Sound input preferences set to Blackmagic Audio. Don't see any input signal in the sound preferences window. Hence nothing getting to FCP7.
Lion 10.7.2
Balckmagic driver 9.0
PowerMac 8 core
Peter McAuley
AXYZ
Toronto
Gene Colburn
Re: Decklink HD Extreme 3D audio input.
on Jan 16, 2012 at 1:14:28 am
Make sure you have a sync reference to the ref. input. Tri-sync, or black.
Peter McAuley
on Jan 16, 2012 at 1:18:52 pm
Oh ya forgot about that. Thanks I'll give it a go.
Peter McAuley
Axyz Edit
Toronto
Joshua Helling
on Jan 16, 2012 at 10:15:20 pm
And if that isn't it, make sure that your decklink preferences are set to analog audio input (that's not set through FCP). That needs to be set from the Decklink Control panel.
For instance if you are using SDI video and analog audio, on the input drop down you should change the setting to SDI video and analog audio as it will default to SDI video and SDI audio.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
Rob Lederman
on Aug 20, 2013 at 5:33:07 pm
A bit late, but I would like to jump in. We have the Decklink HD Extreme 3D+ PCI card. We have the Multibridge Utility. We can not change anything. You mention above about the Control Panel. Huh? What Control Panel. What am I missing?
Thanks in advance.
Rob Lederman
North Avenue Post
Rob Lederman
Sr. Smoke Editor / Compositor / FCP / Resolve
North Avenue Post
rob@northavenuepost.com
