DisplayVideoFrameSync memory leaks problem
Mauro Gattari
on Jan 9, 2012 at 2:59:30 pm
I'm trying to write a small C program that outputs frames to the card, but I'm experiencing memory leaks problems.
The program is very simple, after having enabled video output:
deckLinkOutput->EnableVideoOutput(bmdModeHD720p50, bmdVideoOutputFlagDefault);
It starts outputting frames at 50fps within a loop in which:
1. create an output video frame:
deckLinkOutput->CreateVideoFrame(
1280, 720, 1280*4,
bmdFormat8BitBGRA, bmdFrameFlagDefault,
&videoFrame);
2. write raw data within the frame (just a pattern of RED or GREEN pixels)
3. display the frame:
deckLinkOutput->DisplayVideoFrameSync(videoFrame);
4. release the frame:
videoFrame->Release();
videoFrame = NULL;
The program works, but memory consumption grows fast (1MB per second) and I can't understand why since I think I'm correctly releasing a video frame before creating a new one.
Can anybody give me any help?
Linux Ubuntu 11.10
DeckLink Studio
Drivers 9.0
This is the whole source code:
#include "simple.h"
#include "DeckLinkAPI.h"
#include
#include
#include
IDeckLink* deckLink = NULL;
IDeckLinkOutput* deckLinkOutput = NULL;
IDeckLinkMutableVideoFrame* videoFrame = NULL;
unsigned char* publicCreateOutputVideoFrame()
unsigned char* outBytes = NULL;
HRESULT result = deckLinkOutput->CreateVideoFrame(
1280, 720, 1280*4,
&videoFrame);
if (result != S_OK)
return NULL;
result = videoFrame->GetBytes((void**)&outBytes);
return outBytes;
void publicDisplayVideoFrameSync()
/* ULONG refCount = */ videoFrame->Release();
videoFrame = NULL;
void cleanUp()
if (deckLinkOutput != NULL)
deckLinkOutput->DisableVideoOutput();
if (deckLink != NULL)
deckLink->Release();
deckLink = NULL;
int setUp()
IDeckLinkIterator* deckLinkIterator;
HRESULT result;
deckLinkIterator = CreateDeckLinkIteratorInstance();
if (deckLinkIterator == NULL)
fprintf(stderr, "A DeckLink iterator could not be created. The DeckLink drivers may not be installed.n");
return 1;
// Get the first DeckLinkCard
result = deckLinkIterator->Next(&deckLink);
if (result != S_OK)
fprintf(stderr, "Could not obtain the IDeckLink interface - result = %08dn", result);
goto bail;
result = deckLink->QueryInterface(IID_IDeckLinkOutput, (void**)&deckLinkOutput);
if (result != S_OK)
fprintf(stderr, "Could not obtain the IDeckLinkOutput interface - result = %08dn", result);
goto bail;
bail:
deckLinkIterator->Release();
deckLinkIterator = NULL;
return 0;
int main()
const int fps = 50;
const int nrOfFramse = fps*60*1; // fps * seconds * minutes
int i,j;
unsigned int pattern;
setUp();
for(j=0; j nrOfFramse; j++)
unsigned char* frame = publicCreateOutputVideoFrame();
if (frame != NULL)
if ((j/fps)%2==0)
pattern = 0x0000ff00;
else
pattern = 0x000000ff;
for(i=0; i<1280*720; i++)
((unsigned int *)frame)[i] = pattern; // AARRGGBB
publicDisplayVideoFrameSync();
usleep(1000000/fps);
getchar();
cleanUp();
return 0;
Joshua Helling
Re: DisplayVideoFrameSync memory leaks problem
on Jan 16, 2012 at 7:28:17 pm
Might be best to contact developer@blackmagic-design.com to get help with this issue.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
Mauro Gattari
on Jan 16, 2012 at 7:30:57 pm
Yes,
I already contacted the developers and they acknowledged the issue. They are working on it, I'm waiting for the fix release.
