Hyperdeck Studio and DNxHD 2.0 Beta 1 update not working!!!
Zulkarnain Kamarul Zaman
on Jan 7, 2012 at 7:02:48 pm
I was thrilled to hear that Hyperdeck would soon be able to capture in DNxHD codes. But after several attempt, I still couldn't record in DNxHD even after selecting it in the utility window. It always revert back to uncompressed. Anyone who has successfully apply the update, pls share the experience and perhaps a correct way to execute the update.
chris north
Re: Hyperdeck Studio and DNxHD 2.0 Beta 1 update not working!!!
on Jan 12, 2012 at 9:58:13 am
We purchased the Hyperdeck Studio a few weeks ago and I upgraded to the Beta 2.0 software. Everything went very easily and the device now records MXF files. The device was connected via USB to the Mac and I used the installer from Blackmagic's Website.
Biggest drawback for us at the moment is that there is no indication on the display as to the file that is being recorded, nor is it possible to maintain different timecodes per clip.
But otherwise cool.
chris
Richard Wirth
on Jan 20, 2012 at 8:07:11 pm
Everything we record is .mov so I guess the Hyperdeck Studio is reverting back to uncompressed QT everytime I set it to DNXHD even though the Utility is set at DNXHD.
Guess we're waiting for the release version now, too.
Just out of curiosity, what resolution of DNXHD does it default to? Since I haven't gotten the machine to do it, I can't tell.
Nick Stephens
on Jan 15, 2012 at 9:36:51 am
Hi there, we are having exactly the same problem.
Were you able to fix it? If so, how?
Local Blackmagic people have suggested the following, but we have not had a chance to try yet:
1) Downgrade the unit to 1.1.2 Firmware, Remove the USB 2.0 Cable and Power Cycle (off/on) the HyperDeck Studio.
2) Uninstall the 1.1.2 Firmware from the PC/Mac, restart the Mac and install the 2.0 Beta 1.
3) Plug in the USB 2.0 Cable, power-on the HyperDeck Studio, Open THe HyperDeck Utility and Flash the firmware to Beta2.0 firmware.
4) Once the update is finished, remove the USB 2.0 Cable, Power-cycle the HyperDeck Studio And reconnect the USB 2.0 Cable to the PC/Mac.
5) Now, Open the HyperDeck Utility, Select the Open Of DNxHD and try to capture again.
Does this work?
Tonio Kruger
on Jan 16, 2012 at 12:53:19 pm
i have the same problem here. I have tried this procedure many times now, without success.
HyperDeck Utility allways revert to 10 Bit uncompressed.
on Jan 17, 2012 at 7:26:50 am
Hi all,
I've done the procedure several times also to no avail. Currently Blackmagic advised me to send in the unit for a possible replacement.
However I,ve just updated my second unit and the updates works. My question now is, how to use the mxf material in FCP since it records 1 video and 2 audio files separately. With a rather limited experience with Avid codecs, I'd appreciate any input and assistant from fellow forumers.
Tq
Tonio Kruger
on Jan 17, 2012 at 8:17:56 am
Black Magic Support advised me to wait for the release version of the Hyperdeck Studio Software.
They are still working on a fix for this issue that should be available to the public at some point in the near future. Nice.
Tonio Kruger
DoP / Colorist
http://www.toniokrueger.com
Grzegorz Staszek
on Jan 24, 2012 at 10:33:10 pm
Hello
How import DNxHD files from Hyperdeck Studio to Avid Media Composer 6.0 ?
J have 3 files - 1 video and 2 audio
Nick Stephens
on Jan 25, 2012 at 12:06:18 pm
Have you tried the Beta 2 now available from the website?
Nick Stephens
on Jan 31, 2012 at 1:10:51 pm
Latest from local BlackMagic support:
Yes the online Beta, aka with the latest release is to fix this bug.
A little explanation on what it will do. It will change the firmware toggling timing to be shorter, thus addressing the issue of not able to switch between DNxHD and Uncompressed.
It should fix the problem which you are facing.
Do kindly try it out ;-)
Richard Wirth
on Jan 31, 2012 at 11:12:58 pm
Okay, it's working now for us. Many thanks for the updated software.
So DNXHD 220x is a 59.94 codec.
Any news as to when DNXHD 175x will be accommodated?
