About Hyperdeck Shuttle
Ahmed Sajid
on Dec 20, 2011 at 12:43:43 pm
I hope this is the right place to ask.
I am about to order a Hyperdeck shuttle, to do a greenscreen recording on the Sony F3. I just wanted to confirm a few things,
1. Will I be able to use it as an HD-Sdi to HDMI converter, so that i can run an HDMI feed from the HS, to a monitor, even when its not recording ?
2. Is there a loop-out function on Sdi, so I can get another feed to go on to a waveform monitor ?
3. What wrapper does it use for uncompressed 422 files ? I am guessing a .mov , would like to confirm anyway.
Thank you in advance.
Kristian Lam
Re: About Hyperdeck Shuttle
on Dec 20, 2011 at 9:44:48 pm
[Ahmed Sajid] "1. Will I be able to use it as an HD-Sdi to HDMI converter, so that i can run an HDMI feed from the HS, to a monitor, even when its not recording ?
Yes, you can. You can even use it as a battery powered converter when when you don't have an SSD inserted.
Yes, all outputs as active.
3. What wrapper does it use for uncompressed 422 files ? I am guessing a .mov , would like to confirm anyway."
You're correct. It's a Quicktime compatible .mov file.
regards
Kristian Lam
Blackmagic Design
