Unable to install H.264 Pro Recorder on windows 7 - 64Bits home edition
João Manuel Tocha
on Dec 6, 2011 at 5:00:36 pm
Hi! I am not able to install the Pro Recorder on my laptop, after I install Desktop Video 9, i connect the usb cable from the unit and it start's "Installing device driver software" -> searching windows update and then it gives the following message: Failed
Any ideias? on the mac I had no problem installing the device, and everything worked has expected, it even updated the firmware of the device.
Thanks in advance.
João Tocha
Benjamin Gilmore
Re: Unable to install H.264 Pro Recorder on windows 7 - 64Bits home edition
on May 8, 2012 at 8:11:50 am
Hi João, I was just wondering if you found a solution to your problem? We are having the same issue on one of our studio computers at the moment...
Roger Jennings
on Jan 18, 2013 at 8:05:50 pm
Hi João,
I, too, am having this exact same problem. Did you find a solution that you can share?
Roger
