Intensity Pro in Premiere Pro CS5.5.2 Programmonitor Vektor, RGB etc. dont Show changes realtime
Andre Wollenberg
on Dec 3, 2011 at 12:55:12 am
in Premiere CS 5.5.2 Sequence BM->HD->AVCHD->Interlaced->50i (but also in other sequences) when i switch the programm monitor to Vektor or RGB Parade or anything, and use fast colorkorrektion as examble the Program Monitor don't shows the changing in Realtime, after i switched to an other sequence or close the file and open it later. This only happend in BM Sequences. This is very urgent for me, because i use the BM Intensity Pro for colorgrading on outputing Monitor, so i cant make the colorgrading w/o the intensity Pro.
