Mixed Resolutions and Dropped frames
Charlie Carr
on Nov 29, 2011 at 4:14:43 pm
Hey all. Still trying to figure out my Decklink Extreme 3d. I'm working on a MacPro 2.26 quad core 16gb ram and 10.6.7 with FCP 7.0.3
Previously i was having problems with dropped frames and real time effects. Since i have switched my prores sequences to 8bit uncompressed, as i'm playing out to an HD monitor with component signal. Via the black magic 1920x1080 8bit 23.98 setting. So i'm living with that.
My latest hurdle which i've been researching all morning is SD in an HD timeline. I'm cutting a project that 90% is HD files as prores 422. I have film dailies that were digitized from dvcam as dv. When i cut the dv into the 8bit time line it goes in with out a render color bar. but then in playback it drops frames, and i can't render it. I've also tried recompressing the dv to 8bit uncompressed and prores 422, but still running into the same problem. Anyone else encounter this. is there a fix, or is it just a problem when working with mixed resolutions?
charlie
