Does the analog to SDI mini-converter upconvert?
Joel Bialek
on Nov 21, 2011 at 9:32:01 pm
Sorry if this has been answered before, but I'm trying to engineer a new video system and am looking at BMD to fit the bill. I'm planning on using an ATEM 1M/E, but I want to be able to get an SD DVD player into the switcher while still maintaining a 1080i program output.
Would the Analog to SDI converter do this for me? Or do I need to use a combination of the Analog and the Up/Down/Cross converter?
Thanks ahead of time.
Joel
Bob Zelin
Re: Does the analog to SDI mini-converter upconvert?
on Nov 22, 2011 at 2:52:00 am
you need both. Analog to SDI to convert to SDI 525 NTSC, and the "up converter" to go from SD-SDI to HD-SDI.
Bob Zelin
Joel Bialek
on Nov 22, 2011 at 2:28:56 pm
Thanks Bob. I appreciate it.
Marc Colemont
on Nov 30, 2011 at 7:26:08 pm
What about delay when using the upconvertor?
Robert Dewerff
on Dec 7, 2011 at 12:05:49 am
I use both inline often, when converting from a DVD-player to HD-SDI. SDI monitor patched at first conversion, and at second up convert. I have not noticed a delay... So I guess it would be better to say the delay, if any, is not noticeable.
In the world of individual frames, this answer may not be acceptable.
Bob D
America One Networks
Evan Vickers
on Aug 16, 2012 at 6:25:06 pm
Wouldn't it be easier to use the Component input of the ATEM 1/ME?
You should just need a DVD player cable of upscaling to the same format you run your system.
