ATEM 1 M/E vs. AV-HS400A
Will Murray
on Nov 20, 2011 at 11:00:33 pm
Hi Guys,
Looking for a little input.... Currently running a Panasonic HS400A with 4 HD-SDI + 2 DVI sources. I had a chance to investigate the new ATEM switcher and broadcast panel over the weekend and wonder what I'd potentially be losing by moving to the ATEM? I noticed right away that the ATEM doesn't have built in tally or PTZ control, but interested in seeing what else might be missing. I also hope the H.264 output from the ATEM TV Studio makes it in to the 1 M/E eventually.
Will
silvio guedes
Re: ATEM 1 M/E vs. AV-HS400A
on Nov 21, 2011 at 11:49:51 pm
Comprei recentemente o Atem 1 e sinto falta de 2 itens que para mim é muito importante.
Primeiro. Possibilidade de usar clips de videos mais longos com formatos populares como, wmv, avi, mpeg e etc...
Segundo. Possibilidade de gravar um formato mpeg4 apartir de seua saida usb 3.0.
Fora isto, para mim está muito bom.
Hampus Lager
on Nov 22, 2011 at 2:59:03 pm
You can get tally with the latest firmware and a ATEM camera converter via SDI, but I don't have enough knowledge about tally yet to say more.
You can't reassign buttons yet. Button 1 is linked to input 1 (HDMI or component), buttons 2-4 to input 2-4 (HDMI) and buttons 5-8 to input 5-8 (SDI). I heard rumours about them working to fix this as a firmware update.
