ATEM 16:9 SD input
Raphael Schricke
ATEM 16:9 SD input
on Nov 18, 2011 at 2:53:14 pm
I am thinking of buying an ATEM TV Studio for our live productions.
My question is : I read that you can input a SD Pal signal 720x576.
But what if it is in 16:9 instead of 4:3 ? Will this be an issue for the ATEM Switcher ?
Will it show the video in the good 16:9 format in the multiview and in the program ?
Thanks a lot for your help.
Eric van Engelen
Re: ATEM 16:9 SD input
on Nov 21, 2011 at 9:35:26 am
At this moment is can process your signal. But the multiviewer shows it as 4:3. Which makes the switcher quite unusable in SD-productions.
I've mailed with Blackmagic several times since early august, but they won't give a timeframe for when they will fix this issue with an update.
Until then we'll have to rent a another switcher for each SD-production, which is **#* annoying.
