Intensity Pro....no SD capture
Scott Francis
on Nov 10, 2011 at 12:46:16 am
I have had an Intensity Pro card for about a year now, used to be able to capture from Beta SP desk YUV through the card into either Media Express OR Vegas 10 in SD format. No longer the case, I have tried BM Desktop versions 8.0-9.0 to no avail. I have to upconvert SD to HD in the BM menu and then I am able to capture in Vegas and then set to SD fromat in the NLE. Also cannot capture anything from composite or S-video anymore as well. Only real change is the drivers from BM...anyone else have this issue? Thanks in advance!
Warmly
Scott Francis
Mind's Eye Audio/Video Productions
Danny Hays
Re: Intensity Pro....no SD capture
on Nov 13, 2011 at 6:33:49 pm
You are selecting composite or s video in your BM control panel right? Also the source input must match the capture settings in Media Express prefs or it won't work.
Scott Francis
on Nov 22, 2011 at 1:03:44 pm
THANKS DANNY! I had not seen that option in the newer versions! It was not there before in 2.6 that worked fine....I will try that out. I was only aware of the BM control panel.
Regards
Scott Francis
