prores based premiere projects ?
Noe Marti
on Nov 7, 2011 at 12:36:24 pm
I try to switch from fcp to premiere.
all my projects are prores based.
Is it possible to continue with a fully prores based workflow in premiere? Native editing of prores files in premiere and output them via bmd hardware?
couldn't figure out correct settings in premiere. The sequence settings (editing mode & playback settings) in premiere seem to be not as flexible as in fcp.
what would be an equivalent QT workflow format to premiere+bmd like what I had: fcp+prores on bmd hardware ?
is there anything as good as prores 422hq / prores4444 ?
or will mediacomposer 6 allow me to edit native prores files and output them via mutlibridge pro2 ?
kind regards.
macpro 8core (2008), 16 gb ram
osx 10.6.8
fcp7 & premierepro 5.5
multibridge pro 2 - desktop video 9
Chris Tompkins
Re: prores based premiere projects ?
on Nov 7, 2011 at 3:18:38 pm
Yes you can.
Do you have BMD sequence settings?
There is a lot of talk about premiere temp edit files and final exporting.
You can import Prores files and edit with them and feed the BMD hardware.
You can edit with proxy files for faster workflow and export to a prores master.
Chris Tompkins
Video Atlanta LLC
© 2018 All Rights Reserved
