Intensity to Dell
William Edwards
Intensity to Dell
on Nov 2, 2011 at 3:17:50 am
Hello,
I was wondering if I could hook up the Blackmagic Intensity to the Dell Ultrasharp U2410 24" LCD monitor. I am going to be working on an SD feature, editing and coloring.
Can I do that through the component connections?
Kristian Lam
Re: Intensity to Dell
on Nov 3, 2011 at 2:28:55 am
Hi William,
Yes, that will work. You can use the Dell like a regular component display via the Intensity Pro's component analog output.
regards
Kristian Lam
Blackmagic Design
William Edwards
on Nov 3, 2011 at 4:18:23 am
Is there a Blackmagic device similar to the Intensity that doesn't have a Thunderbolt connection? Say, if I have a MacPro?
Kristian Lam
on Nov 3, 2011 at 6:43:44 am
[William Edwards] "Is there a Blackmagic device similar to the Intensity that doesn't have a Thunderbolt connection? Say, if I have a MacPro?
You can use the Intensity Pro which is a PCIe card.
regards
Kristian Lam
Blackmagic Design
