Breakout connector type on Decklink Extreme 3D
Alex Maranda
on Nov 1, 2011 at 10:27:57 pm
Ok I know this one is a bit from the left field...I'm making a custom breakout cable for the Decklink Extreme 3D+ going straight to panel connectors in a multicam setup.
I've no idea what type this slim 25P high density connector is!
On Intensity it's a 26P HD D-type, and I've made my custom cable with it.
The Decklink Extreme connector is beautiful alien....can someone from Blackmagic please chime in with a connector code/type. I'm not looking for support for what I'm doing, just for this critical piece of info.
Much appreciated!
Jacob Griffith
Re: Breakout connector type on Decklink Extreme 3D
on Mar 12, 2012 at 10:31:08 pm
The connector is made by Molex. The Molex part number for the connector you need is 83424-9014. Do a search on Google and you'll see that Mouser and Digikey both stock it. I ran across this forum post when doing a google search trying to figure out how to buy one of those connectors.
Also, what kind of cable are you making? In other words, which of the connections will you be using? I will be making a cable with just the 2 XLR inputs connected.
