SDI capture on my Decklink 3D Extreme
Ray Rahman Anwar
on Oct 27, 2011 at 3:52:53 pm
How do I activate my SDI input on the Decklink 3D Extreme Card.
I can get see my HDMI but SDI I cant receive any input, just blank.
I am a newbie to SDI so what do I click to get the picture.
Am disappointed that the card cant capture Dual SDI.. :(
I have no problem getting HDMI. (1080i at 50hz)
What us the setting i have to change to in order to get SDI.?
I use this for my ArKaos MediaMaster Pro..
Chris Pearse
Re: SDI capture on my Decklink 3D Extreme
on Oct 28, 2011 at 8:06:02 am
Hi Ray,
To switch between the different inputs on the card you would just need to goto either System Preferences (on Mac) or Control Panel (in Windows) and then the Blackmagic control panel. Here you should find a dropdown box for 'Set Input'. You would just need to change this to the relevant SDI option.
If you continue to have problems, please contact your regional support team. You can use the support forms from the support pages here:
http://www.blackmagic-design.com/support/
Or by calling the support numbers on the page here:
http://www.blackmagic-design.com/company/
Chris Pearse
Technical Support Consultant
Blackmagic Design EMEA
Ray Rahman Anwar
on Oct 28, 2011 at 10:08:14 am
Hi Chris,
I tried that but No signal.
I had to use the SDI - HDMI Heavy Duty Convertor and convert my SDI to HDMI.
Will try that later after my event.
Thanks. if there is a problem I will call up my distributor.
Cheers
