ATEM 2.6 Update
Ronak Desai
ATEM 2.6 Update
on Oct 10, 2011 at 8:54:28 am
I've been anxiously waiting for the USB 3.0 update (Version 2.6) for the ATEM Production Switchers. Does anyone know if the output on the USB will work with Adobe Flash Media Live Encoder? I currently do not own one....yet.
Matt Drabick
Re: ATEM 2.6 Update
on Oct 11, 2011 at 2:39:33 pm
Ronak, I will test this is soon.
The ATEM 2.6 addes the following:
• Uncompressed capture via USB 3.0 with ATEM 1M/E Production Switcher
• UltraScope monitoring via USB 3.0 with ATEM 1M/E Production Switcher
• Support for tally via Ethernet with the Blackmagic GPI and Tally Interface
• Support for tally via SDI to the ATEM Camera Converter
• General performance and stability improvements
Should be interesting!
Matt Drabick,
DigiTek Systems
Ronak Desai
Re: ATEM 2.6 Update
on Oct 12, 2011 at 5:15:40 am
Thanks, I look forward to the results!
Dean Anderson
Re: ATEM 2.6 Update
on Oct 12, 2011 at 5:29:13 pm
Do you know if this also includes being able to use Quicktime and AVI clips in the media pool? Also, have you attempted to capture yet with the USB 3.0, and do you know if that includes compatibility support for Adobe OnLocation/Premiere Pro?
Dean Anderson
John Williams
Re: ATEM 2.6 Update
on Oct 21, 2011 at 9:32:09 am
I have just installed the 2.6 update and can't get either Media Express or Ultrascope to work. The upgrade all went OK and the software installed to the main unit OK. I have checked the NEC Chip software as well to make sure that it is OK.
Has anybody seen this all working?
Regards,
John
