render settings for Hyperdeck
Tobias Trummer
on Oct 5, 2011 at 9:40:47 am
We try to do the following:
render SD-mov for Hayperdeck with a LTC-Wav muxed in on 3&4
Could this work? the aim is, to sync a third device via that LTC.
Sony Vegas - no success at all
Premiere - once with original audio YES, another try with LTC: NO
Today with premiere with same settings: NO even without LTC, that worked few days ago...
Is there any recommended workflow to achieve that (SD with 1&2 orig. audio / 3&4 LTC) ??
Are there any more recommendations than:
"...simply needs to make sure that the file is encoded in 10 bit Uncompressed YUV 4:2:2 with a .mov wrapper, and is in a broadcast standard format that the HyperDeck Shuttle supports. If these conditions are met it should work nicely. If the customer is using Final Cut Pro 7 or Premiere Pro CS5/5.5, and have the Desktop Video drivers installed, they should be able to export using those settings."
Tobias.
Tobias Trummer
Re: render settings for Hyperdeck
on Oct 10, 2011 at 2:23:29 pm
Is there any proofed workflow to render videofiles for hyperdeck (studio)?
Any help appreciated...
