hd sdi -> LTC
jason levy
hd sdi -> LTC
on Sep 26, 2011 at 7:22:48 pm
I note that Blackmagic makes an HD SDI to analog converter. Can one use this to extract embedded time code? Else does anyone else know of a box that does this?
Jason
Bob Zelin
Re: hd sdi -> LTC
on Sep 26, 2011 at 10:32:51 pm
Why I know the answer to this, and neither AJA or Blackmagic make it.
It's made by Cobalt Digital, and it fits right into an OpenGear chassis, so you can mix and match with all the Blackmagic cards ! -
bob Zelin
TIMECODE AND LTC EMBEDDING/DE-EMBEDDING
+LTC - Timecode Prioritization and LTC Embedding/De-Embedding Solution
Cobalt is enhancing the capabilities of their 9000 series COMPASSĀ® and Fusion3GĀ® cards by offering options for a complete timecode prioritization and LTC embedding/de-embedding solution. The new option, +LTC, allows bidirectional transfer and conversion between VBI timecode formats and audio LTC, as well as RS-485 LTC. Audio LTC can be received over selected balanced analog audio, embedded or AES input channels, and sent as digital audio over selected embedded or AES output channels. End-users can easily set timecode priorities via the DashBoard GUI. If preferred format is detected, it is automatically selected. If not, another format is used as previously established in a priority list by the end-user.
