Hitting Stop in Final Cut Pro 7 gives 2/3 frames delay in Sequence with Decklink cards
Paul Jay
on Sep 26, 2011 at 2:47:22 pm
I have this problem with different MacPro systems using Decklink cards. Decklink Studio, Decklink 3D.
The problem is not there with External Video OFF.
The Decklink cards give 2/3 frames delay after hitting stop in the Sequence.
Frame offset to 0 of 4 makes no difference.
I know that working with markers is a workaround but why is this happening?
AJA cards don't have this latency when hitting spacebar to stop.
John Pale
Re: Hitting Stop in Final Cut Pro 7 gives 2/3 frames delay in Sequence with Decklink cards
on Sep 26, 2011 at 6:57:51 pm
Neither does Decklink, when it is working right.
Uninstall, then reinstall your driver package.
Download the latest from their site. Not from your CD,
Paul Jay
on Oct 5, 2011 at 3:37:17 pm
Done that, Latest drivers, always.
Same problem on different MacPro's with different Decklink Cards . Not with AJA card in same MacPro systems.
Other idea's?
John Pale
on Oct 6, 2011 at 3:22:21 am
Have you contacted BMD support?
Paul Jay
on Oct 6, 2011 at 8:34:10 am
Yes, and they usually respond much quicker here on the Cow :)
