Multibridge Pro 2 and 5D Mark II
Paolo Castellano
on Sep 20, 2011 at 3:01:55 pm
Hello,
I'm trying to use a Multibridge Pro 2 (in converter mode) to convert the HDMI out of a 5D Mk II into HD-SDI (with audio embedded). The video is OK, but the audio disappears after some seconds (2 seconds from the beginning of any clip playback).
I tried with other HDMI devices, and there are no problems, as well as connecting the 5D to an HDMI monitor.
Does anybody know if there are compatibility problems with Multibridge and 5D?
Otherwise, anybody is using a BMD Mini Converter HDMI to SDI to convert th 5D HDMI to HDSDI without problems?
Best Regards,
Paolo
Paul Jay
Re: Multibridge Pro 2 and 5D Mark II
on Sep 21, 2011 at 9:06:06 am
No clean progressive HD feed will come out the 5d hdmi.
Forget it:)
Paolo Castellano
on Sep 23, 2011 at 10:14:51 am
Thank you Paul;
do you know an hardware CF Media Player (with SDI or HDMI clean outputs) that supports files created with Canon 5D Mk2 and/or Canon XF300/305?
Best Regards,
Paolo
Paolo.Castellano@ivs.it
http://www.ivsEdits.com
"Post Fata Resurgo"
