DeckLink Studio FCP to HD-SDI out
Brandon Morris
on Sep 12, 2011 at 2:41:21 pm
Is there a reason why I can only use the RGB 8-bit/10-bit settings for playback when I connect the SDI cable from the DeckLink SD/HD-SDI out port to my Sony Trinitron broadcast monitor? But when I connect the SDI cable to the SDI out on the Break Out cable, I can use the BlackMagic HD 1080p and 720p settings for playback. Just wondering if I can avoid using the breakout cable for OCD sake sine there is a SDI out built onto the card. Right now we only need the SDI and HDMI in and out ports on the card.
Brandon Morris
http://www.brandonmorris.com
Canon T2i
13" Macbook Pro (Mid 09) 8GB RAM 10.6
