Intensity Quality in SD Live Acquisition
Dan Asselin
on Aug 31, 2011 at 2:10:20 am
I have recently begun recording seminars and interviews with some quality SD cameras and a small portable PC. Always looking for extra quality I was wondering if acquiring an Intensity Pro would give me an edge over the firewire method I am using. Thanks for your time.
Paolo Castellano
Re: Intensity Quality in SD Live Acquisition
on Aug 31, 2011 at 2:49:22 pm
Hello Dan,
assuming that you are capturing from Firewire into DV format, using an Intensity Pro you could improve quality capturing from HDMI or YUV (no composite or Y/C) using a better codec (4:2:2 color sampling and higher data rate).
Best Regards,
Paolo.Castellano@ivs.it
http://www.ivsEdits.com
"Post Fata Resurgo"
Dan Asselin
on Aug 31, 2011 at 4:26:36 pm
Thanks.
Does that mean that I wouldn't be able to achieve any improvement if I am bringing the signal in from S-Video or Composite?
Regards;
Dan
Paolo Castellano
on Aug 31, 2011 at 6:30:31 pm
You're right, Composite bandwidth is very limited (it is very difficult if not impossible to separate Luma and Chroma without loosing a lot of quality), S-Video is better, but not better than Firewire.
Best Regards,
Paolo
"Post Fata Resurgo"
Dan Asselin
on Aug 31, 2011 at 6:34:05 pm
Thanks a bunch that's what I needed to know. I very much appreciate your time. Dan
Paolo Castellano
on Sep 1, 2011 at 9:01:21 am
:-) You're welcome!
"Post Fata Resurgo"
