Blackmagic Intensity Pro Driver Problem
Joey Chilson
on Aug 30, 2011 at 4:06:52 pm
I'm having a problem with getting my Intensity pro working. I placed the card into the PCI slot in the back of my computer. I turn it back on and install the latest driver from online. I believe it's 3.5. The installment completes and it ask me to restart so I do. When Windows boots up you can till there is an audio lag. The start up sound is laggy. I log in and when I move the mouse it lags across the screen and basically Windows is all laggy. It then ask me too update firmware and I click install and it doesn't. I get an error and I restart my computer and it doesn't shut down. It gets stuck on the "shutting down..." screen and I'm forced to hard shut down. I restart my computer up and disable both Audio and the basic driver and restart and the computer is back to normal. So it's something with the driver I believe.
This is Windows 7 64 bit.
Any help would be amazing.
P.S I worked for like 5 sec before then start the lag again.
Paolo Castellano
Re: Blackmagic Intensity Pro Driver Problem
on Aug 31, 2011 at 3:03:25 pm
Hello Joey,
be careful with hardware compatibility. Driver 3.5 is out of date (replaced by desktop video 8.x, with 8.5 as the last available build), but I had no problems in the past with v.3.X
Best Regards,
Paolo
Paolo.Castellano@ivs.it
http://www.ivsEdits.com
"Post Fata Resurgo"
Joey Chilson
on Sep 3, 2011 at 12:38:55 pm
I have tried the latest drivers and I have the same problem.
daniel jones
on Dec 26, 2011 at 9:31:27 pm
Hey my computer is having the same exact problem, did you ever find a solution for it?
daniel jones
on Dec 26, 2011 at 9:35:29 pm
I have had the same problem too, Have you figured at a solution?
