Black Magic Media Express 2.3 Fullscreen
Kevin Hunter
on Aug 22, 2011 at 8:55:08 pm
Hello,
I am currently using BM Media Express 2.3 to record xbox game play in HD. At the moment, everything is fine. The only problem is that the window is a bit to small. However, if I go into "full screen mode", the window is significantly larger than my screen in both dimensions.
I have 2 monitors (extended desktop) each outputting 1680 x 1050. No idea if it helps, but I capture movies at 720p @ 59.94FPS.
In COMPACT VIEW, the size of the window is 1296 x 815, and the size of the video view port is about 830 x 480.
In FULL SCREEN VIEW, the size of the window is about 1920 x 1210, and the size of the video view port is about 1050 x 602 (which is still not even close to 720p!).
So far I have not found a setting of any sort to change this. The goal here it to make the video view port window as close to 720p as possible without losing any of window.
Thanks in advance.
Kevin Hunter
