HDLink Pro separate LUT's for SDI/DVI
Toby Tomkins
on Aug 22, 2011 at 4:50:59 pm
Hi all,
Quick question (hopefully). Can you have separate LUTs applied to the SDI-out and the DVI(HDMI)-out?
I want to know as I want to run a grade 1 monitor off HD-SDI and projector off HDMI (DVI), both needing different LUT's for accurate monitoring.
Also, is it worth getting the display-port model or will the DVI (with HDMI convertor) output 10 bit (or will only the display-port)
Toby
Kristian Lam
Re: HDLink Pro separate LUT's for SDI/DVI
on Aug 22, 2011 at 5:07:54 pm
[Toby Tomkins] "Quick question (hopefully). Can you have separate LUTs applied to the SDI-out and the DVI(HDMI)-out?
You can only run 1 LUT and they apply to both the SDI out and the DVI/HDMI output.
[Toby Tomkins] "Also, is it worth getting the display-port model or will the DVI (with HDMI convertor) output 10 bit (or will only the display-port)
The DisplayPort version will support 10-bit HDMI but the DVI version is 8-bit HDMI/DVI.
regards
Kristian Lam
Blackmagic Design
