VGA into intensity pro
Elendill elendill
on Aug 1, 2011 at 8:46:40 am
I am trying to capture laptop's VGA output with an intensity pro.
I bought a VGA to Component cable but it doesn't work.
What should I do ?
Bob Zelin
Re: VGA into intensity pro
on Aug 1, 2011 at 11:37:49 pm
http://www.markertek.com/Video-Equipment/Video-Processors/Scan-Converters/E...
Under $5000, and will work wonderfully.
There are cheaper solutions, but I want you to spend the $5000.
bob Zelin
Danny Hays
on Aug 2, 2011 at 12:31:04 am
They make VGA to HDMI adapters.
http://tech.pronto.com/mpm/shop/vga-to-hdmi-adapter?adid=1247069325-8097742...
Elendill elendill
on Aug 4, 2011 at 7:20:35 am
I've found it :
MCAD - Audio Vidéo/Périphériques Vidéo 051231 - 80€
http://www.konektikpc.com/produits/Accessoires-Image/MCAD/MCAD-Audio-Video-...
Drake Hatfield
on Oct 18, 2011 at 5:39:11 pm
I have absolutely NO interest in spending $5000 on an adapter for the $150 card.
Elendill, did it work? I am still struggling to solve this issue myself. I purchased an Aluratek VGA to DVI/HDMI adapter... Insanely strong in terms of build quality, can't get anything to my card! If you found a solution then I want to jump on that bandwagon.
Also, if it works for you, what frame rate and resolution are you capturing at?
