Formating SATA111 SSD's For Use In The Hypershuttle
John Higgs
on Jul 18, 2011 at 6:34:48 pm
Can any one out there tell me how to format my OCZ 240GB Vertex 3 SATA111 SSD in a Mac Pro?.
i can format a SATA11 but Black Magic recommend SATA111. Is it that the Mac Pro is not compatible with SATA111 if so what other way is there?.
John Higgs.
Alex Gerulaitis
Re: Formating SATA111 SSD's For Use In The Hypershuttle
on Jul 18, 2011 at 7:59:43 pm
SATA III is backward compatible with SATA II (or the original SATA for that matter), so you should be able to pop your SATA III SSD into a Mac Pro and format it, no problem. If for some reason you can't, it's not a problem with SATA III - it's some other issue.
Alex (DV411)
John Higgs
on Jul 19, 2011 at 8:24:39 am
I connect the SATA111 via a USB dock to Mac Pro but it does not show in the disk utility, a SATA11 does, this leads me to think that the Mac is not compatible with SATA111 SSD'S.
John Higgs.
Alex Gerulaitis
on Jul 19, 2011 at 8:31:05 am
Methinks that particular drive is having issues with that particular dock. My girlfriend says it happens to her all the time.
Alex (DV411)
John Higgs
on Jul 19, 2011 at 9:59:04 am
I think my problem has been solved, Apple has yet to incorporate SATA111 controllers in the Mac, info of the net.
