USB 3.0 PCI/PCIe card and Intensity Shuttle
Aaron Pulicano
on Jul 13, 2011 at 9:42:42 am
I was looking for confirmation on weather or not a USB 3.0 addon card will work with the shuttle and my motherboard. My motherboard is an X48 with one free PCI slot (other PCI slot is being used by soundcard) and two free PCIe 1x (gen one) slots. I was looking at the following two USB 3.0 addon cards:
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128331
PCI USB 3.0 card
http://www.newegg.com/Product/Product.aspx?Item=N82E16815201041&cm_re=usb_3...
PCIe USB 3.0 card
http://www.newegg.com/Product/Product.aspx?Item=N82E16815166026&cm_re=usb_3...
I really only need enough bandwidth for HDMI 480p capture with 8 Channel LPCM audio.
Looking forward to a reply!
Thank you
Bill Ravens
Re: USB 3.0 PCI/PCIe card and Intensity Shuttle
on Jul 16, 2011 at 4:46:51 pm
I have this setup on my workstation. It works...sorta. The display will freeze occasionally. Hitting Ctrl-Alt-Del will restore operation. Kind of a PITA, but, it works.
Aaron Pulicano
on Jul 16, 2011 at 4:57:08 pm
Hi, thanks for the reply. What USB 3.0 card and motherboard are you using? Could you link the USB card? Since your system can not use the full 3.0 bandwidth, what have you found the Shuttle to max out when using this setup? Is 480p the max you can capture (with audio) hdmi or rca audio? Do both HDMI can Component capture work?
If I couldn't get the Shuttle to work, I was also thinking of getting a MXO2 Mini, which does up to 1080p30 using a PCIe x1 slot and supports 8-Channel LPCM too, just does not support 480p can costs $200 more.
Bill Ravens
on Jul 17, 2011 at 11:47:39 am
The USB3 PCI card was one recommended by BMD(Asus U3S6), however, it was very hard to find, since it is no longer manufactured.
Aaron Pulicano
on Jul 17, 2011 at 12:08:41 pm
That is a PCIe x4 card, my motherboard is not made by Asus and only has a (Gen 1) PCIe x1 and PCI slot free. I don't think it will work even for (due to lack of bandwidth) 480p... and I doubt BMD will respond for confirmation.
