Intensity Pro and Premiere Pro CS5.5 - jerky playback even after Rendering...
Christian Schaefer
on Jul 7, 2011 at 10:39:41 pm
Hey :-)
I have a problem:
I use a Intensity Pro with Adobe Premiere Pro CS5.5.
And I playout the Timeline through HDMI to a Flat-TV...
The problem is, it is not possible to playout my Timeline (1080i50) without the playback gets interuppted!!!
After a few seconds the playback stopps...
Even if I render the whole Workarea the playback stopps (if I use some particular Effects for example the 3D-Effect...)
Some other Effects for example the Ultra Keyer will playback smoothly (after Rendering the timeline)...
I don't know what I do wrong....
Can yomeone help me?
ok, my PC is not the fastest
Dual Core, 3 GB RAM, IWndows Vista 64bit
But why the UltraKey is played out smooth after rendering and the 3D-Effect not?
Christian Schaefer
Re: Intensity Pro and Premiere Pro CS5.5 - jerky playback even after Rendering...
on Jul 7, 2011 at 10:52:47 pm
oh I just found the solution self....
I have made a 3D PiP Effect (with the 3D-Effect)...
I have rendered the video and the playback always stops.
Its because I have no background used (just transparent > black)...
If I use a picture or Video as background the playback is smooth ;-)
Joshua Helling
on Jul 14, 2011 at 6:06:47 pm
Christian,
Thanks for sharing this. At first I was thinking that you were dropping frames and was gonna ask about your hard drive setup, but this is very interesting. So if you have no video in a background (id assume your V1 is being used as the source of the pip) you are getting this problem?
I'd be interested in getting a sample project that shows this so we can check and send this to engineering.
If you're so inclined you can email that to support-usa@blackmagic-design.com. Put ATTN: Joshua in the subject and reference this post. That way we can check and look into this a bit more.
But really appreciate you posting your finding!
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
