Use Decklink 3d to capture two completely seperate streams?
Eric Giesberg
on Jun 29, 2011 at 3:24:26 pm
So I know this question gets asked a decent amount around here on how to capture multiple streams simultaneously (and synced) to multiple files.
I was looking at my options, I can possibly get the Decklink Duo for ~$500 and use a 3rd party program such as ivsCapture Pro for $990.
I was curious to see if I could use two identical cameras with the Decklink HDextreme to record the seperate streams simultaneously and have them to save to different files instead. Is this possible, or am I better off just getting ivsCapture Pro?
Eric Giesberg
Re: Use Decklink 3d to capture two completely seperate streams?
on Jun 29, 2011 at 4:52:49 pm
I'm sorry for doubling posting. The third option is Sony Vegas Pro. It seems to have the ability to record two streams simultaneously as well but I can't seem to verify this anywhere.
Paolo Castellano
on Jul 1, 2011 at 12:36:30 pm
Hello Eric,
if you have to capture 2 streams only, in my opinion is better to get 2 Decklink SDI cards; the Decklink Duo lacks of the Serial Ports that can always be useful. If you need 4 or more inputs, or if you need 2 inputs and 2 outputs, it could be better to get 2 x Duo or 1xQuad (The Decklinks are not Full-Duplex).
Best Regards,
Paolo Castellano
http://www.ivs.it
Paolo.Castellano@ivs.it
http://www.ivsEdits.com
"Post Fata Resurgo"
Eric Giesberg
on Jul 5, 2011 at 7:05:45 pm
Thank you for the quick response.
Is the full duplex really necessary? We only really need the outputs on these as pass-throughs/downconverters to NTSC for an overhead TV (for monitoring the feeds). I assume if I didn't read incorrectly that they can do this without an issue while still allowing recording into the computer.
