Decklink HD Extreme 3d HDMI Issue
Kyle Krupinski
on Jun 27, 2011 at 3:47:59 pm
We just purchased a Decklink HD Extreme 3d Plus card for use with Final Cut Pro and soon Davinci Resolve. We have a 42" OLED TV mounted above our Edit bay monitors for client reference that is hooked up through a 50 foot HDMI cable (our computer is located in a machine room across the hall from our suite). We where using a Matrox LE system before to feed the TV and there where no issues. But now with the Decklink Card, there is a strange color fringe that is causing a rainbow of colors to display across the image.
I've played around with settings on the drivers and nothing has changed. The only thing I can think of is maybe the cable run is too long? Anyone else experience this before?
Kyle Krupinski
Alex Gerulaitis
Re: Decklink HD Extreme 3d HDMI Issue
on Jun 27, 2011 at 9:04:10 pm
How were you connecting Axio LE to HDMI? Axio LE does not have HDMI I/O if I remember right:
http://www.matrox.com/video/media/pdf/products/axio/en_AxioLE.pdf
Only Cat2 HDMI cables are guaranteed to work for up to 49ft:
http://en.wikipedia.org/wiki/HDMI#Cables
It doesn't mean a Cat1 won't work, it's just only Cat2 is guaranteed so. Bottom line, it seems that you'd want to order a Cat2 cable.
Also, if you ever plan to monitor 1080p, 4K, 3D (i.e. transmit that signal over to the TV), you may need to get an HDMI extender, or a cable that is specifically guaranteed to transmit 4K/3D.
Alex (DV411)
Alex Gerulaitis
on Jun 27, 2011 at 9:35:11 pm
(duplicate, sorry)
