Capture Problem Using Decklink Intensity Pro/Direct Show in VB.NET
Philip Hardy
on Jun 23, 2011 at 9:46:16 am
Hi all
I'm trying to implement some direct show functionality using a Decklink Intensity Pro capture card. I've created and run the graphs I need in GraphEdit with no problem (to both render on screen and capture to file) but when I try to implement either in VB.NET the output is just a black screen. Note I'm trying to implement this new functionality on a 64 bit version of Windows 7.
Connecting to remote graph when the app is running produces the same graph that I created initially, but when run in GraphEdit also outputs a black screen, then replacing the capture source filter with the one from the filter list in GraphEdit produces correct results again. This leads me to believe I'm configuring the capture source filter incorrectly in my code, or its assuming the incorrect settings from whatever source.
Here's the code I'm using to try to write from the capture source output to file. Am I supposed to be setting up the capture source filter in a different way? Any suggestions would be greatly appreciated.
Thanks in advance
Private m_dsROT As DsROTEntry
Private m_graphBuilder As IFilterGraph2
Private m_mediaCtrl As IMediaControl
Private m_mediaEvent As IMediaEvent
Private m_mediaSeeking As IMediaSeeking
Private f_videoCapture As IBaseFilter = Nothing
Private f_mjpegCompressor As IBaseFilter = Nothing
Private f_aviMux As IBaseFilter = Nothing
Private f_fileWriter As IFileSinkFilter = Nothing
Public Sub StartCapture(ByVal path As String)
m_graphBuilder = DirectCast(New FilterGraph(), IFilterGraph2)
m_mediaCtrl = DirectCast(m_graphBuilder, IMediaControl)
m_mediaEvent = DirectCast(m_graphBuilder, IMediaEvent)
m_mediaSeeking = DirectCast(m_graphBuilder, IMediaSeeking)
#If DEBUG Then
m_dsROT = New DsROTEntry(m_graphBuilder)
#End If
Try
'Adding the selected video source filter to the filtergraph
Dim videoDevice As DsDevice = SharedFunctions.GetVideoDevice(VideoDeviceName)
hr = m_graphBuilder.AddSourceFilterForMoniker(videoDevice.Mon, Nothing, videoDevice.Name, f_videoCapture)
DsError.ThrowExceptionForHR(hr)
Catch ex As Exception
Throw New Exception("Error adding video source filter to the graph (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Adding Decklink MJPEG Compressor to the filtergraph
Dim mjpegCompressorGuid As New Guid("1E003B41-B606-4AE4-B2BB-C35E133575A5")
Dim mjpegCompressorComtype As Type = Type.GetTypeFromCLSID(mjpegCompressorGuid)
f_mjpegCompressor = DirectCast(Activator.CreateInstance(mjpegCompressorComtype), IBaseFilter)
hr = m_graphBuilder.AddFilter(f_mjpegCompressor, "Decklink MJPEG Compressor")
Throw New Exception("Error adding Decklink MJPEG Compressor to the graph (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Connecting pins
Dim videoDeviceOut As IPin = DsFindPin.ByName(f_videoCapture, "Capture")
Dim mjpegCompressorIn As IPin = DsFindPin.ByName(f_mjpegCompressor, "XForm In")
hr = m_graphBuilder.Connect(videoDeviceOut, mjpegCompressorIn)
Throw New Exception("Error connecting video source and mjpeg compressor filters (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Adding AVI Mux to the filtergraph
'Dim aviMuxGuid As New Guid("E2510970-F137-11CE-8B67-00AA00A3F1A6")
'Dim aviMuxComtype As Type = Type.GetTypeFromCLSID(aviMuxGuid)
'f_aviMux = DirectCast(Activator.CreateInstance(aviMuxComtype), IBaseFilter)
f_aviMux = DirectCast(New AviDest, IBaseFilter)
hr = m_graphBuilder.AddFilter(f_aviMux, "AVI Mux")
Throw New Exception("Error adding AVI Mux to the graph (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Connecting pins
Dim mjpegCompressorOut As IPin = DsFindPin.ByName(f_mjpegCompressor, "XForm Out")
Dim aviMuxIn As IPin = DsFindPin.ByName(f_aviMux, "Input 01")
hr = m_graphBuilder.Connect(mjpegCompressorOut, aviMuxIn)
Throw New Exception("Error connecting mjpeg compressor and avi mux filters (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Adding FileWriter to the filtergraph
f_fileWriter = DirectCast(New FileWriter(), IFileSinkFilter)
f_fileWriter.SetFileName(path, Nothing)
hr = m_graphBuilder.AddFilter(f_fileWriter, "File Writer")
Throw New Exception("Error adding File Writer to the graph (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Connecting pins
Dim aviMuxOut As IPin = DsFindPin.ByName(f_aviMux, "AVI Out")
Dim fileWriterIn As IPin = DsFindPin.ByName(f_fileWriter, "in")
hr = m_graphBuilder.Connect(aviMuxOut, fileWriterIn)
Throw New Exception("Error connecting avi mux and file writer filters (" & hr & "). " & ex.Message, ex.InnerException)
End Try
Try
'Start the capture graph.
hr = m_mediaCtrl.Run
RaiseEvent StartedRecording()
Throw New Exception("Error starting the capture graph (" & hr & "). " & ex.Message, ex.InnerException)
End Try
End Sub
