Ultra Scope/Black level adjustment
jay agoglia
on Jun 2, 2011 at 5:18:23 pm
Hi All!
asking the professionals what I should use to:
Monitor sdi (SD&HD) video signals from VTRs (Digi beta, HD Cam, HD Cam SR)to analyse and display black/white/color video levels to determine legal/illegal video levels?
also what is the best way to adjust these levels to proper specs when proceeding to capture/encode/digitize?
I was looking at the black magic ultra scope so that I may patch in any video signal and see multiple video displays. But I believe I can not adjust the levels in the ultra scope software. Is this correct?
Do I adjust the signal from the decks or with a separate hard ware/ software unit?
we commonly receive many commercial spots by digi beta tapes and FTP (playing out a vela card sd&hd) and need to input this method of monitoring video levels and hopefully adjusting levels as well. We use clip-mail and pipeline mostly to encode and digitize.
any help of thoughts would be greatly appreciated.
thank you !!
-Jason A
Bob Zelin
Re: Ultra Scope/Black level adjustment
on Jun 2, 2011 at 9:49:27 pm
the Ultrascope is a scope. You don't fix things with a scope.
You adjust your levels with a proc amp, or TBC adjustments on your VTR. No matter what anyone tells you, you are never going to learn how to adjust levels on a user forum like this. You need to be trained. You can go to http://www.tek.com, and look up to see if they have any training material on reading a waveform monitor.
Bob Zelin
jay agoglia
on Jun 3, 2011 at 12:01:36 am
Thanks Bob!
I will check the link and start learning about the controls and adjustable parameters on our VTRs.
thanks again,
-j
