From Decklink 10 bit SD to Decklink 10 bit 720P via AJA FS1
Andreas Wideroe
on May 31, 2011 at 1:25:07 pm
I need some help here.
Is there a way to play back a 10 bit SD BM file on a PC with Mediaexpress, route the playback videosignal via SDI out into an AJA FS1 and out via SDI to another PC running Mediaexpress to capture a upconverted clip?
I hope to avoid going to tape ... The last part works well, but I'm not sure how to playback and send the videosignal out via SDI. Is this even possible with Mediaexpress?
Cheers,
Andreas
Andreas Wideroe
Re: From Decklink 10 bit SD to Decklink 10 bit 720P via AJA FS1
on Jun 1, 2011 at 9:08:17 pm
Never mind. I got it to work. Playback in Premiere. Recording in mediaexpress on another machine.
Norsk Smalfilm AS
http://www.smalfilm.no
Filmshooting | Com
http://www.filmshooting.com
