Blackmagic decklink won't install in a Dell PC?
Carly Smith
on May 30, 2011 at 11:49:11 am
Has anyone else had trouble installing a Blackmagic decklink HD card in a Dell running Win 7 64 bit?
Spent quite a bit of time with the folks there trying to get it to work (apparently Dell doesn't like the drivers) but they did not have a suggestion as to what make/model would work?
Card is a Decklink HDPro SD that will connect to an analog to SDI Mini Converter (also made by Blackmagic) so we can use it with our Vaddio board that has 6 inputs.
Yes we are still using analog boards at this time - can't afford to upgrade to HD yet.
All suggestions appreciated...
TIA
C
Paul Jay
Re: Blackmagic decklink won't install in a Dell PC?
on May 30, 2011 at 12:41:12 pm
Works in a MacPro 100 out of 100.
Carly Smith
on May 30, 2011 at 1:34:57 pm
thanks but we won't be converting to Macs anytime soon. That is not an option for us.
Alex Gerulaitis
on Jun 2, 2011 at 10:58:43 pm
Carly,
Which Dell is it? What are the error messages if any?
Have you tried installing the card in a non-Dell system to rule out a possibility of a defective card?
Alex (DV411)
