Capturing DVI signal with Decklink Extreme
keith lostracco
on May 27, 2011 at 3:57:37 am
I've just started to do some tests on being able to capture a DVI signal from Nvidia Quadro video card with a DVI/HDMI adapter with my Decklink HD Extreme card with no success. I've search this forum and found other users with the same problem. I also noticed that Blackmagic Design rep had said they would look into the problem. Are there any updates?
I'm testing this for a new machine I'm getting next week. I do live visuals for events and will be capturing one machine and processing the signal further with another. I will buy another card if I have to but if a Blackmagic card won't work I might have to look into buying another.
Another solution I've found is to us a DVI/VGA adapter and then a VGA to component transcoder that will convert the signal from VGA RGB to Y-Pb-Pr. Will this work?
I would prefer to stay digital but if this is my only option then I'll go that way.
If there is no solution with Blackmagic does anyone else know of any other cards capable?
thanks
Keith
