Does the Intensity shuttle work with p67
Themi Themistocleous
on Apr 22, 2011 at 1:14:06 pm
I have an Alienware Aurora R3, i7 2600k with built in USB 3 (NEC Renesas) ports. Has any body managed to make the shuttle work with the new P67 boards. I need to convert many analog formats to digital. I would like to use the Intensity shuttle based on its Technical specs but it seems many people struggle with it. I know it specificaly supports the x58 based boards but it does say "x58 or P55 series or better Windows computers" in the technical specs.
Kristian Lam
Re: Does the Intensity shuttle work with p67
on Apr 29, 2011 at 12:24:08 pm
Hi Themi,
We have some positive reports from other customers about the P67 motherboards with the Renesas NEC host controllers so there's a high chance it will work.
regards
Kristian Lam
Blackmagic Design
on May 17, 2011 at 1:18:28 pm
Hi Kristian
Thanks for the reply.
i have got the Intensity shuttle.
I updated all usb drivers. It connected fine. Raid performance was fine. see speedtest.
It sees the analog devices but have frames droping on analog video 8 bit on most devices.
I have just updated to the latest Blackmagic software 8.01 and renesas driver update which was releast last weak hoping to solve this. driver 2.1.16.0 and firmware to 3027.
Still dropping frames. What now??
regards Themi
