DV PAL - reversed field-order
Christian Schaefer
on Apr 19, 2011 at 2:16:04 pm
Hello,
I use a "Intensity pro" to playout The After Effects (CS4) Timeline...
My Project is Standard PAL (720x576 interlace)...
If I import a normal DV-PAL-Clip (captured through Firewire) and play it out, the field order is reversed!
I have done some Tests and play-out the DV-Clip (PAL) in After Effects through a Firewire-Device (Camcorder with DV-In)
=> The Fields are shown correctly!
If I play out the same Test-Clip through "Blackmagic Video Output" the Fields are reversed!
That means if I use "BM-Video Out" the Field-Order is reversed, but this happens only with DV-Clips not with Clips captured with Blackmagic-Codec!
What can I do?
Christian Schaefer
Re: DV PAL - reversed field-order
on Apr 21, 2011 at 10:13:14 am
Someone else have this problem???
Claus-Peter Wolf
on May 1, 2011 at 8:33:38 am
Hi christian,
i have the same probleme with dv since years and years.
Wrote many time to bm and this forum, but never get a
faluable answer.
I hoped with every new driver, that i would be solved.
But after years i gaved up.
Now, when i have DV-material i digitalize it
with a DVCam deck with SDI out.
I know, it donĀ“t help you, but i can tell you,
you are not alone ;-)
Greating from Cologne
claus-Peter
