H.264 Pro
Scott Francis
H.264 Pro
on Apr 19, 2011 at 12:24:34 pm
Anyone use this to capture from the optical of a camera and encode bypassing internal camera compression. Wondering if this is a better format than HDV (quality wise)
Scott
Scott Francis
Scott Francis
Mind's Eye Audio/Video Productions
Danny Hays
Re: H.264 Pro
on Apr 19, 2011 at 2:41:30 pm
I answered this on the Sony Vegas forum. Take a look.
Luke Maslen
Re: H.264 Pro
on Apr 19, 2011 at 11:54:28 pm
Hi Scott,
H.264 is full resolution codec and will store a full 1920 x 1080 pixel image. By comparison, HDV deliberately loses some of the picture and saves it at 1440 x 1080 to keep the data rate low.
HDV uses 4:2:0 chroma subsampling whereas H.264 Pro Recorder uses 4:2:2 so the color is better with H.264.
This does not mean that you should rush out and convert all your HDV material to H.264 but if you have a choice of acquiring new material in one format or the other, I would suggest choosing H.264.
Regards,
Luke Maslen
Blackmagic Design
Scott Francis
Re: H.264 Pro
on Apr 20, 2011 at 12:08:23 am
I have not been able to see and "system requirements" on this unit..I currently capture via firewire to laptop and tape on my Sony FX1's. The picture I see is MUCH nicer on my component preview than the HDV codec that I am recording to. What are the computer requirements for this unit? I have some older laptops that do fine with HDV, and since it is a hardware converter, is the computer just capturing data?
Thanks for your help!!
Regards
Scott Francis
Scott Francis
Alex Geroulaitis
Re: H.264 Pro
on Apr 20, 2011 at 12:34:13 am
Ditto, don't see minimum system requirements. At the very minimum (pun intended), would like to see "any computer with a USB 2.0 interface able to capture up to 480Mbit/s (60MB/s)".
It would be great to know the minimum OS requirements; how to set or change encoding data rates if possible; what are the pre-set or maximum encoding data rates for a given incoming signal.
Alex (DV411)
