HDLink Pro 3D DisplayPort -> DVI-D
Ben Richardson
on Mar 13, 2011 at 3:37:44 am
I'm getting an HDLink Pro to use with my DeckLink and JVC monitor which lacks SDI.
I intend to upgrade the JVC at some point – likely with a DisplayPort compatible monitor – so it seems wise to get the DisplayPort model of the HDLink over the DVI-D model.
Am I right in thinking that in order to get to the DVI-D input on my current monitor I simply need a passive DisplayPort to DVI-D cable or adapter? (HD only, no dual link for 2k currently required.)
(A simpler question, if it's the right one, might be: is the DisplayPort model "DisplayPort Multi-mode" compatible?)
Neil Sadwelkar
Re: HDLink Pro 3D DisplayPort -> DVI-D
on Mar 14, 2011 at 4:34:14 am
You could even get a DisplayPort to HDMI converter.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Ben Richardson
on Mar 17, 2011 at 7:58:43 pm
The answer was yes, the HDLink Pro 3D DisplayPort works perfectly with my JVC with both BMD's recommended Monoprice Displayport to DVI-D adapter, and a cheap DisplayPort to DVI-D cable from Amazon.
Which begs the question, who *wouldn't* be better off buying the DisplayPort model of the HDLink over the DVI-D model?
