HDlink PRO doesn't show any HD format to Panasonic TH-42PF20
Mikhail Puzyrev
on Mar 10, 2011 at 10:58:21 am
PAL is ok, when I switch to any 720 or 1080 format - plasma switch to no signal state. Source is Decklink Extreme 3D+, Software - Davinci Resolve.
Margus Voll
Re: HDlink PRO doesn't show any HD format to Panasonic TH-42PF20
on Mar 11, 2011 at 5:58:58 am
Maybe there is some frame rate issue ?
Margus
http://iconstudios.eu
Mikhail Puzyrev
on Mar 12, 2011 at 7:56:36 pm
The same plasma connected to the HDMI output of Extreme 3D without HDlink works as intended - showing the picture in ALL the videomodes chosen at Davinci project tab. So it's strictly HDlink issue which sends wrong signal to plasma. So I would like to know how to fix it.
Bob Zelin
on Mar 13, 2011 at 9:06:15 pm
gee, why don't you try putting a 29.97 signal on the monitor from your system, instead of 23.98, and see what happens ? How long will that test take you ?
Then, if you have a Y Pb Pr output on your Decklink/AJA card, plug directly into your monitor with the CAV signal, and test that without the HD Link Pro, to see if that works.
Bob Zelin
Mikhail Puzyrev
on Mar 13, 2011 at 10:15:41 pm
Hello Bob!
Straight from Decklink Extreme 3D from HDMI out to Panasonic DVI input - works great (from 1080 23,98 to 60, so 720, but I lose the ability to load 3D LUTs which HDLink Pro has.
