Web streaming - Intesity shuttle or Ultra studio pro
scott robinson
on Mar 3, 2011 at 7:33:53 pm
Hi All,
I was hoping to find out if the Intensity shuttle or the Ultra studio would be a good solution for live event video streaming?
I was interested in using one of these units to capture SD video into a computer with a USB 3.0 connection. I was planning on encoding with Window Media Encoder or Expressions.
Any advice or work flows would be appreciated.
Chad Pearson
Re: Web streaming - Intesity shuttle or Ultra studio pro
on Mar 3, 2011 at 8:53:14 pm
We currently do this today. We use an Intensity Shuttle hooked up to a Dell Optiplex 980 and stream it using Adobe FMLE to our CDN. We initially had a problem with the preview window open on FMLE causing dropped frames (probably a bug in the BM directshow driver), but once we turned off the preview window everything worked fine.
I've also tried it with Microsoft Expression Encoder 4 Pro, but it suffered from the same 'preview window' bug and I couldn't figure out how to turn it off like I could with FMLE.
Since then BM's documentation now says Dell's are not supported, so if you don't have one you shouldn't have a problem.
