Ultrascope in MacPro is extremely slow
Paul Jay
on Mar 1, 2011 at 9:50:33 am
We have a MacPro 8 core 2.4 ghz , 24 GB ram with a ATI5870 with a Ultrascope built in. Latest Ultrascope drivers are installed.
It takes 3 seconds for a shot to arrive on the Ultrascope Screen and the scopes/meters are jittering.They just can't keep up.
When just having 1 parameter up it does speed up.
What could be the problem?
I've tested the Ultrascope on different MacPro's with different ATI cards but it's all the same.
Paul Jay
Re: Ultrascope in MacPro is extremely slow
on Mar 1, 2011 at 10:01:07 am
So the GTX285 is the only certified card for a MacPro.
But you can't buy it anymore because it has been discontinued.
Will Blackmagic support other Nvidia's or ATI later?
Sascha Haber
on Mar 3, 2011 at 4:08:03 pm
Just buy one on ebay or get the Quadro 4000
A slice of color...
DaVinci 7.1 OSX 10.6.6
Dual Xeon 2,4 RAM 24 GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE
Paul McDonald
on Mar 3, 2011 at 11:46:29 pm
Hi Paul,
This doesn't directly relate to your situation, but we were having similar issues with our PC ultrascope box. From the day the system arrived it had similar playback issues to what you've been experiencing - 2-3 second lag with picture and steppy playback far from realtime (like 5 fps).
After a lot of back and forth with the local distributors the problem was isolated down to the latest graphics drivers that the system came with. The 4650 card was running 11.x drivers. We completely uninstalled these and reinstalled v10.2 drivers and the machine now works perfectly.
Not sure if that relates to your situation with a Mac but it could be worth a shot. Call your distributor to confirm which version of drivers the card is supposed to work with.
Cheers
