BM Intensity Pro - Double Screen when Capturing 1080p 30
Herman Ming
on Feb 8, 2011 at 9:38:36 pm
I am having trouble capturing at 1080p 30. What I am doing is capturing using the Blackmagic Intensity Pro card via HDMI from one computer to another computer.
Here are the specs:
Record Computer
Intel Core Quad 9550 2.8ghz
8GB Ram
Windows 7
Source Computer
Intel i3
Asus Motherboard
EVGA Geforce 8400GS
Ubuntu 10.10
The source is coming from the Geforce card using a DVI-to-HDMI converter, then the HDMI into the Blackmagic Intensity Pro HDMI input. Mind you, I am capturing from Linux, but I reckon that shouln't really have any major issues - I did install the appropriate Nvidia drivers.
In Media Express, I only get a signal for two settings... 1080i 60 and 1080p 30. THis is regardless of whatever output settings I put on the source computer. In fact, it seems that media express doesn't even care what refresh rate I set the source computer output at. It will only pick it up using those two settings. Now the problem isn't capturing at 1080i 60. It seems to work fine. But I am trying to get it to work capturing at a progressive rate. And the signal shows up, but it shows up like this:
http://www.hmchen.com/bmip1.jpg
This is so baffling to me! I don't know how this is even so. I'm hoping someone else has run into this problem too and fixed it, but so far I haven't found any. If there's any way I can make it so it stretches back to one, that'd be great!
If you hvae any advice, thanks!!
jared hobbs
Re: BM Intensity Pro - Double Screen when Capturing 1080p 30
on May 23, 2012 at 2:09:49 pm
I'm having the same double stacking issue. Did you fix this issue? This didn't occur until I was prompted to do an update.
<a href="http://s19.photobucket.com/albums/b182/dreamatek/?action=view&current=IntensityProMediaExpressdoublestacking.jpg"><img src="http://i19.photobucket.com/albums/b182/dreamatek/IntensityProMediaExpressdoublestacking.jpg" border="0" /></a>
jared hobbs
on May 23, 2012 at 2:28:41 pm
Well, got it working. Had to change the capture settings to 1080i 59.94
