Input Mode Detection for Intensity Pro using DeckLink SDK
Naveed Gazi
on Feb 8, 2011 at 5:10:01 pm
Hi all,
As the subject suggests, I'm trying to automatically determine what display mode to choose based on the device connected to my Intensity Pro card via HDMI, using the DeckLink SDK. I went through the documentation and realized that Input Mode detection is not inherently supported for the Intensity Pro but I was wondering whether a work around is possible. I was thinking of looping through all the display mode indexes until I successfully received an appropriate frame. This would require grabbing a frame from the VideoInputFrameArrived() call back, and reinitializing all interfaces/pointers with the next display mode index if the call back function failed to return a frame.
There are some problems with this approach, for instance attempting to stop the video/audio streams from the call back function will force the program to go into a bad state and it did, resulting in a segfault.
Has anybody managed to find a work around to this limitation? Any advice/suggestions to my approach are more than welcome.
Naveed
Joshua Helling
Re: Input Mode Detection for Intensity Pro using DeckLink SDK
on Feb 16, 2011 at 6:42:56 pm
Hello,
Unfortunately this feature of the SDK only works on Decklink SDI, Decklink Optical fibre and Decklink Duo.
We've gotten a number of requests for this feature to be added to other cards but if/when we are going to do that has yet to be decided.
I hope that helps.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
