Capturing doesn't stop at end-time
Sascha Teuber
on Feb 7, 2011 at 4:41:41 pm
Hi!
I am having the problem that the capturing doesn't stop at the given end time. I have to press ESC and say don't delete the file. That's not pretty.
I am using:
Windows XP Pro 32 Bit SP3
Decklink 7.9.3
Thx!
Sascha
Joshua Helling
Re: Capturing doesn't stop at end-time
on Feb 16, 2011 at 7:17:15 pm
Odd...what app are you using to capture? In most apps you are either capturing a timecode range or crash capture. If you've got a timecode marked clip (with a timecode stripe that is not broken) then the capture be it in Media Express 2 or Premiere Pro will stop when the clip has finished capturing.
If you simple click to capture in the app it will not stop just because the tape runs out.
Are you using a different app that supports a "capture time limit" function?
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc.
