Decklink Extreme HD 3D analog audio with SD-SDI video
Neil Sadwelkar
on Jan 29, 2011 at 4:29:52 am
I've just had 4 systems installed with Decklink Extreme HD 3D cards. Drivers are 7.6.3, MacOSX 10.6.4, FCP 7.0.3.
SD-SDI video out is fine, with embedded audio too.
But analog audio along with SD-SDI video isn't working. Went over the settings, even System Prefs > Sound. FCP sequence is 2-track with output settings to match. I am getting picture out of the SD-SDI and there's embedded audio in there too. This is happening on 2 identical systems, by the way.
Is this a limitation of the Decklink Extreme HD 3D? That it cannot output analog audio over the analog audio jacks on the break out cable simultaneously with SD-SDI video?
I going to try again today with Decklink drivers 7.9.5 and with Media Express for playback.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Neil Sadwelkar
Solved: Decklink Extreme HD 3D analog audio with SD-SDI video
on Jan 29, 2011 at 11:56:33 am
Solved.
Downloaded and installed Blackmagic Decklink 7.9.5, firmware updated and now analog audio out with SDI video is available.
Whew!
Neil Sadwelkar
twitter: fcpguru
Mumbai India
